Garmin Connect Settings
You can customize your device settings, run options, and user settings on your Garmin Connect™ account. Some settings can also be customized on your Approach® X40 device.
- From the settings menu in the Garmin Connect Mobile app, select Garmin Devices, and select your device.
- From the devices widget in the Garmin Connect application, select Device Settings.
After customizing settings, synchronize your data to apply the changes to your device (Synchronizing Your Data with the Garmin Connect Mobile App) (Synchronizing Your Data with Your Computer).
- Device Settings on Garmin Connect
- Run Options on Your Garmin Connect Account
- User Settings on Your Garmin Connect Account
Parent Topic: Customizing Your Device
