Pairing Your Smartphone
To get the most out of your Approach® X40 device, you should pair it with your smartphone and complete the setup using the Garmin Connect™ Mobile app.
NOTE:
Unlike other
Bluetooth® devices that are paired from the
Bluetooth settings on your mobile device, your
Approach X40 device must be paired directly through the
Garmin Connect Mobile app.
- On your compatible smartphone, download and install the latest version of the Garmin Connect Mobile app.
- Open the Garmin Connect Mobile app.
Select an option to add your device to your
Garmin Connect Mobile account:
If this is the first device you are pairing with the Garmin Connect Mobile app, follow the on-screen instructions.
If you have already paired another device using the Garmin Connect Mobile app, from the settings menu, select .
- On your Approach X40 device, press the device key to view the menu.
- On your Approach X40 device, select .
- On your compatible smartphone, select Search For Device.
Parent Topic: Pairing and Setup
