Viewing TruSwing Metrics on Your Device
Before you can use the TruSwing™ feature on your Approach® device, you must confirm your TruSwing device is securely mounted to your club. See the owner's manual for your TruSwing device for more information.
  1. Turn on your TruSwing device.
  2. On your Approach device, press the device key to view the menu, and select Swing analysis.
  3. Select a club.
  4. Hit a shot.
    Swing measurements appear on your Approach device after each swing.
  5. Swipe up or down to move through the recorded swing metrics.
Copyright © Garmin. All rights reserved.GUID-EA9A7DC4-2C26-4EEF-A2F4-D458B1D7CF1D v2
