Bluetooth Settings
Press the device key to view the menu, and select .
- Bluetooth
Enables Bluetooth® wireless technology.
NOTE: Other Bluetooth settings appear only when Bluetooth wireless technology is enabled. - Pair Phone
Connects your device with a compatible Bluetooth enabled smartphone. This setting allows you to use Bluetooth connected features using the Garmin Connect™ Mobile app, including notifications and activity uploads to Garmin Connect.
- Notifications
Allows you to enable and configure phone notifications from your compatible smartphone. You can use the Show Calls Only option to display notifications for only incoming phone calls.
- Connect Alert
Allows you to enable an alert informing you when your paired smartphone is no longer within Bluetooth wireless technology range.
- Sync
Synchronizes your device with the Garmin Connect Mobile app.
Parent Topic: Bluetooth Connected Features
