Setting Up the Device On Your Computer
If you have not paired your
Approach® X40 device with your smartphone, you can use your computer to complete the setup process with your
Garmin Connect™ account.
NOTE:
Some device features require a paired smartphone.
- Connect the charging clip securely to the device (Charging the Device).
- Plug the USB cable into a USB port on your computer.
- Go to www.garminconnect.com/golf.
Download and install the
Garmin Express™ application:
If you are using a Windows® operating system, select Download for Windows.
If you are using a Mac® operating system, select Download for Mac.
- Follow the on-screen instructions.
Parent Topic: Pairing and Setup
