Changing the Bands
The device is compatible with 20 mm wide, standard, quick-release bands.
  1. Slide the quick-release pin on the spring bar to remove the band.
    Close-up view of the band being replaced
  2. Insert one side of the spring bar for the new band into the device.
  3. Slide the quick-release pin, and align the spring bar with the opposite side of the device.
  4. Repeat steps 1 through 3 to change the other band.
Copyright © Garmin. All rights reserved.GUID-A67C713E-24B9-4723-9985-518E31B21937 v5
