Customizing the Widget Loop Hold the button. Select > Manage Widgets. Select the toggle switch to add or remove a widget from the widget loop. Parent Topic: Viewing Widgets
Customizing the Widget Loop Hold the button. Select > Manage Widgets. Select the toggle switch to add or remove a widget from the widget loop. Parent Topic: Viewing WidgetsHomeWidgetsViewing WidgetsCustomizing the Widget Loop
