System Settings
From the watch face, hold the button and select
to customize device settings and features.
- Auto Lock
Allows you to lock the touchscreen automatically to prevent accidental touches. Use the During Activity option to lock the touchscreen during a timed activity or round of golf. Use the Not During Activity option to lock the touchscreen in watch mode.
- Backlight
Allows you to enable the backlight and adjust the backlight settings (Backlight Settings).
- Activity Tracking
Allows you to enable activity tracking, move alerts, and goal alerts (Activity Tracking).
- Manage Widgets
Allows you to enable preloaded widgets (Customizing the Widget Loop).
- User Profile
Sets the user profile for gender, birth year, height, and weight. You can also set which wrist your watch is worn on. The gender setting is used for gender-specific course ratings for select tees when calculating handicaps, and for gender-specific par values (where available) (Setting Up Your User Profile).
- Language
Sets the text language on the device.
- Time
Adjusts the time settings (Time Settings).
- Units
Sets the units of measurement for activity distance, golf distance, pace/speed, elevation, weight, height, and temperature.
- Reset
Allows you to reset the device to restore all default settings, or to remove all saved user data and reset all settings on the device (Restoring All Default Settings).
- About
Displays device information, such as the unit ID, software version, regulatory information, and license agreement (Viewing E-label Regulatory and Compliance Information).
- Backlight Settings
- Time Settings
- Setting Up Your User Profile
- Restoring All Default Settings
- Viewing E-label Regulatory and Compliance Information
