Light Network Settings
From the Sensors menu, select Lights, and select a paired light.
- Enable
Turns on the light and allows you to control the light remotely with your Edge® device. You can disable a light to disconnect it from the light network.
- Light Mode
Sets the light intensity and pattern mode, or turns off the light.
NOTE: This setting is available when you select the Individual light mode setting (Light Mode Settings). - Software Update
Checks for software updates.
- About
Displays device, software, and battery information.
- Remove
Allows you to delete a paired light from the network.
Parent Topic: Customizing Headlight Settings with Your Edge Device
