Setting the Keel Offset
You can enter a keel offset to compensate the surface reading for the depth of a keel, making it possible to measure water depth or depth below the keel instead of depth below the transducer. Enter a positive number to offset for a keel. You can enter a negative number to compensate for a large vessel that may draw several feet of water.
  1. Complete an action, based on the location of the transducer:
    • If the transducer is installed at the water line Callout number 1, measure the distance from the transducer location to the keel of the boat. Enter this value in steps 3 and 4 as a positive number to display depth below keel.
    • If the transducer is installed at the bottom of the keel Callout number 2, measure the distance from the transducer to the water line. Enter this value in steps 3 and 4 as a negative number to display water depth. Enter a 0 in this value to display depth below keel and depth below transducer.
    Keel offset with callouts
  2. Select Settings > My Vessel > Keel Offset.
  3. Select Plus or Minus based on the location of the transducer.
  4. Enter the distance measured in step 1.
GUID-1153977F-305D-4F69-B6F0-A214B08E367D v7
January 2025
