My sonar does not work Push the transducer cable all the way into the back of the device. Even if the cable seems to be connected, you should push firmly so that it is fully seated. Check to make sure the sonar transmission is turned on. Parent Topic: Troubleshooting
My sonar does not work Push the transducer cable all the way into the back of the device. Even if the cable seems to be connected, you should push firmly so that it is fully seated. Check to make sure the sonar transmission is turned on. Parent Topic: TroubleshootingHomeAppendixTroubleshootingMy sonar does not work
