Setting the Beeper
You can set when the device makes sounds.
  1. Select Settings > System > Beeper.
  2. Select an option:
    • To have the device beep when you select an item and when an alarm is triggered, select On (Selections and Alarms).
    • To have the device beep only when alarms are triggered, select Alarms Only.
GUID-1153977F-305D-4F69-B6F0-A214B08E367D v7
January 2025
