Pairing a Dog Collar Device with the Handheld Device
NOTE: If your handheld device and dog collar device were included in the same package, the devices are paired from the factory.
  1. On the handheld device, move the toggle switch and select a key to choose the color associated with the dog collar device.
  2. On the handheld device, set the intensity level to a numbered position (Changing the Intensity Level).
  3. On the dog collar device, hold the power key for about 5 seconds until the status LED changes to yellow.
  4. On the handheld device, select a training key.
The dog collar device beeps when the devices have paired successfully. If the device does not beep, pairing has not been successful.
TIP: If the devices did not pair successfully, you should verify the batteries in both devices are fully charged and the intensity level is set to a numbered position.
Copyright © Garmin. All rights reserved.GUID-7A35C55E-C501-4397-B7BF-BDD08922A67C v4
