Choosing the Correct Intensity Level
  1. Set the intensity to the lowest level (Changing the Intensity Level).
  2. Select a training key.
  3. Observe the dog for a reaction, such as a head shake, neck movement, or just a change in expression.
    Sometimes dogs will vocalize due to the surprise of the electrical stimulation. If the dog vocalizes more than once, the intensity level is too high for beginning training.
  4. If there is no reaction, increase the intensity level by one level until the dog has a slight but recognizable reaction to the stimulation.
The intensity level that causes a slight but recognizable reaction is your dog's baseline level for beginning collar training. You do not need to, and should not, apply this intensity selection test again.
After you begin training, the dog’s performance guides your intensity selection. As the dog advances in training, you may need to change the level depending upon the training situation.
Copyright © Garmin. All rights reserved.GUID-7A35C55E-C501-4397-B7BF-BDD08922A67C v4
