Replacing the Pro 70 Dog Collar Device Battery
Before you replace the battery, you must remove all dirt, water, and debris from the device. You also need a small Phillips screwdriver and the security screwdriver included with the battery replacement kit.
You can purchase a replacement battery at http://buy.garmin.com. You should use only an official Garmin® replacement part.
  1. Remove the six screws from the top plate, and remove the top plate.
  2. Remove the two screws from the battery plate, and remove the battery plate.
  3. Grip the battery connector wires close to the connector, and pull the connector parallel to the circuit board to disconnect the battery connector from the device.
  4. Remove the battery.
    The battery fits tightly. It may be necessary to pry the battery out of the back plate using a non-sharp, non-metal object.
  5. Install the new battery into the front enclosure with the label side of the battery facing up, and the leading edge of the battery placed under the charging contact ledge of the device.
  6. Replace the battery plate, and replace and tighten the two screws.
    Line drawing of the battery plate
  7. Verify the gasket is not damaged and is completely seated in the groove.
  8. With the new battery, connect the battery connector to the device.
    When properly installed, the connector plug snaps into the port.
  9. Replace the front plate, and replace and tighten the six screws to secure the front plate.
  10. Verify the gasket is not sticking out of the device.
Copyright © Garmin. All rights reserved.GUID-7A35C55E-C501-4397-B7BF-BDD08922A67C v4
