Replacing the Pro 70 Handheld Device Battery
Before you replace the battery, you must remove all dirt, water, and debris from the device. You also need a small Phillips screwdriver and the security screwdriver included with the battery replacement kit.
You can purchase a replacement battery at http://buy.garmin.com. You should use only an official Garmin® replacement part.
Parent Topic: Pro 70 Battery Replacement Instructions
