Connect the charger securely to the device to charge it using the USB cable (Charging the Device).
You can charge the device by plugging the USB cable into a
Garmin® approved AC adapter with a standard wall outlet or a USB port on your computer. Charging a fully depleted battery takes up to two hours.
Remove the charger from the device after the battery charge level icon
is full and stops flashing.
