Pairing Your Smartphone
Your Forerunner® device must be paired directly through the Garmin Connect™ app, instead of from the Bluetooth® settings on your smartphone. You can pair your Forerunner device with your smartphone during the initial setup or through the menu on the device.
- From the app store on your smartphone, install and open the Garmin Connect app.
- Bring your smartphone within 10 m (33 ft.) of your device.
- Select .
Select an option to add your device to your
Garmin Connect account:
If this is the first time you are pairing a device with the Garmin Connect app, follow the on-screen instructions.
If you already paired another device with the Garmin Connect app, from the settings menu, select , and follow the on-screen instructions.
If you are pairing the device with a new smartphone, remove your device from the Garmin Connect app on your old smartphone, and follow the on-screen instructions on your new smartphone.
- Managing Notifications
- Updating the Software Using Garmin Connect Mobile
- Using Do Not Disturb Mode
- Locating a Lost Smartphone
