Tips for Erratic Heart Rate Data If the heart rate data is erratic or does not appear, you can try these tips. Clean and dry your arm before putting on the device. Avoid wearing sunscreen, lotion, and insect repellent under the device. Avoid scratching the heart rate sensor on the back of the device. Wear the device above your wrist bone. The device should be snug but comfortable. Wait until the icon is solid before starting your activity. Warm up for 5 to 10 minutes and get a heart rate reading before starting your activity. NOTE: In cold environments, warm up indoors. Rinse the device with fresh water after each workout. Parent Topic: Troubleshooting
Tips for Erratic Heart Rate Data If the heart rate data is erratic or does not appear, you can try these tips. Clean and dry your arm before putting on the device. Avoid wearing sunscreen, lotion, and insect repellent under the device. Avoid scratching the heart rate sensor on the back of the device. Wear the device above your wrist bone. The device should be snug but comfortable. Wait until the icon is solid before starting your activity. Warm up for 5 to 10 minutes and get a heart rate reading before starting your activity. NOTE: In cold environments, warm up indoors. Rinse the device with fresh water after each workout. Parent Topic: TroubleshootingHomeDevice InformationTroubleshootingTips for Erratic Heart Rate Data
