If your phone will not connect to the device, you can try these tips.
Turn off your smartphone and your device, and turn them back on again.
Enable
Bluetooth® technology on your smartphone.
Update the
Garmin Connect™ app to the latest version.
Remove your device from the
Garmin Connect app to retry the pairing process.
If you are using an
Apple® device, you should also remove your device from the
Bluetooth settings on your smartphone.
If you bought a new smartphone, remove your device from the
Garmin Connect app on the smartphone you intend to stop using.
Bring your smartphone within 10 m (33 ft.) of the device.
On your smartphone, open the
Garmin Connect app, select
or
, and select
to enter pairing mode.
Select
