The first fitness activity you record on your device should be an outdoor run. You may need to charge the device (Charging the Device) before starting the activity.
Select
Go outside, and wait while the device locates satellites.
Select
to start the timer.
Go for a run.
The timer appears.
Select
or
to view additional data screens (optional).
After you complete your run, select
to stop the timer.
Select an option:
Select
Resume to restart the timer.
Select
Save to save the run and reset the timer. You can view a summary of the run.
NOTE:If your activity was walking, biking, or something else, the device uses
Move IQ technology to determine the activity.
