Running With Virtual Pacer
NOTE:
You must set up
Virtual Pacer™ before starting a run. After you start the run timer, you cannot change the settings.
- Select .
- Enter your pace.
- Go for a run (Going for a Run).
After you turn on Virtual Pacer, it is used every time you go for a run unless you turn it off or enable a different run mode.
Parent Topic: Virtual Pacer
