The device comes partially charged. You may need to charge the device
(Charging the Device) before going for a run. If your
Forerunner® device was packaged with an
ANT+® sensor, they are already paired.
Put on the optional heart rate monitor
(Putting On the Optional Heart Rate Monitor).
Hold
to turn on the device.
Select
Go outside, and wait while the device locates GPS signal.
It may take a few minutes to locate GPS signals. When GPS is located,
appears solid and a timer screen will appear.
When using a heart rate monitor, wait while the device connects to the sensor.
When the device detects the heart rate monitor, a message appears and
appears solid.
Select
to start the timer.
Go for a run.
After you complete your run, select
to stop the timer.
Select an option:
Select
Resume to restart the timer.
Select
Save to save the run and reset the timer. A summary appears.
Select
Discard to delete the run.
