Pairing the Heart Rate Monitor
The first time you connect a heart rate monitor to your device, you must pair the device and sensor. After the initial pairing, the device automatically connects to the sensor when you go for a run and the sensor is active and within range.
NOTE:
If your device was packaged with a heart rate monitor, the device and sensor are already paired.
Parent Topic: ANT+ Sensors
