Using Run and Walk Intervals
NOTE:
You must set up the run/walk feature before starting a run. After you start the run timer, you cannot change the settings.
- Select .
- Set the run time for each interval.
- Set the walk time for each interval.
- Go for a run.
After you turn on the run/walk feature, it is used every time you go for a run unless you turn it off or enable a different run mode.
Parent Topic: Training
