Setting the Run Mode
Select
> Run Options > Run Mode.
Select an option:
Select Basic if going for an outdoor run (Going for a Run) or an indoor run (Training Indoors).NOTE: This is the default run mode.
Select Run/Walk to set run and walk intervals for a run (Using Run and Walk Intervals).
Select Virtual Pacer to help improve your performance (Running With Virtual Pacer).
Select Time, and enter an amount of time, to train toward a specific time goal.
Select Distance, and enter a distance, to train toward a specific distance goal.
Select Calories, and enter an amount of calories, to train toward a specific calorie goal.
Select
When you reach the time, distance, or calorie goal, a message appears. The device also beeps if audible tones are turned on (Setting the Device Sounds).
Parent Topic: Training
