Starting a GroupTrack Session
Before you can start a GroupTrack session, you must pair the watch with a compatible phone (Pairing Your Smartphone).
NOTE: Your paired phone must be equipped with a data plan and be in an area of network coverage where data is available.
These instructions are for starting a GroupTrack session with a fēnix® watch. If your connections have other compatible devices, you can see them on the map. The other devices may not be able to display GroupTrack riders on the map.
  1. On the fēnix watch, hold MENU, and select Safety & Tracking > GroupTrack > Show on Map to enable viewing connections on the map screen.
  2. In the Garmin Connect™ app, from the settings menu, select Safety & Tracking > LiveTrack > Menu > Settings > GroupTrack.
  3. Select All Connections or Invite Only and select your connections.
  4. Select Start LiveTrack.
  5. On the watch, start an outdoor activity.
  6. Scroll to the map to view your connections.
Copyright © Garmin. All rights reserved.GUID-DF9BDE35-F592-4CD8-872D-A2910FAFC147 v7
