Editing an Alarm
  1. From the watch face, hold MENU.
  2. Select Clocks > ALARMS > Edit.
  3. Select an alarm.
  4. Select an option:
    • To turn the alarm on or off, select Status.
    • To change the alarm time, select Time.
    • To set the alarm to repeat regularly, select Repeat, and select when the alarm should repeat.
    • To select the type of alarm notification, select Sounds.
    • To turn the backlight on or off with the alarm, select Backlight.
    • To select a description for the alarm, select Label.
    • To delete the alarm, select Delete.
Copyright © Garmin. All rights reserved.GUID-DF9BDE35-F592-4CD8-872D-A2910FAFC147 v8
