Courses
You can send a course from your Garmin Connect™ account to your device. After it is saved to your device, you can navigate the course on your device.
You can follow a saved course simply because it is a good route. For example, you can save and follow a bike friendly commute to work.
You can also follow a saved course, trying to match or exceed previously set performance goals. For example, if the original course was completed in 30 minutes, you can race against a Virtual Partner® trying to complete the course in under 30 minutes.
Copyright © Garmin. All rights reserved.GUID-DF9BDE35-F592-4CD8-872D-A2910FAFC147 v8
