Using the inReach Remote
Before you can use the inReach® remote function, you must add the inReach widget to the widget loop (Customizing the Widget Loop).
- Turn on the inReach device.
- On your fēnix® watch, press UP or DOWN from the watch face to view the inReach widget.
Press
to search for your inReach device.
Press
to pair your inReach device.
Press
, and select an option:
To send an SOS message, select Initiate SOS.
NOTE: You should only use the SOS function in a real emergency situation. -
To send a text message, select
, select the message contacts, and enter the message text or select a quick text option. -
To send a preset message, select Send Preset, and select a message from the list.
To view the timer and distance traveled during an activity, select Tracking.
Parent Topic: inReach Remote
