Data Fields
NOTE: Not all data fields are available for all activity types. Some data fields require ANT‍+® or Bluetooth® accessories to display data.
% Functional Threshold Power
The current power output as a percentage of functional threshold power.
% Heart Rate Reserve
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
10s Balance
The 10-second moving average of the left/right power balance.
10s Power
The 10-second moving average of power output.
24-Hour Maximum
The maximum temperature recorded in the last 24 hours from a compatible temperature sensor.
24-Hour Minimum
The minimum temperature recorded in the last 24 hours from a compatible temperature sensor.
30s Balance
The 30-second moving average of the left/right power balance.
30s Power
The 30-second moving average of power output.
3s Balance
The three-second moving average of the left/right power balance.
3s Power
The 3-second moving average of power output.
500m Pace
The current rowing pace per 500 meters.
Aerobic Training Effect
The impact of the current activity on your aerobic fitness level.
Ambient Pressure
The uncalibrated environmental pressure.
Anaerobic Training Effect
The impact of the current activity on your anaerobic fitness level.
Average % Heart Rate Reserve
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Average 500m Pace
The average rowing pace per 500 meters for the current activity.
Average Ascent
The average vertical distance of ascent since the last reset.
Average Balance
The average left/right power balance for the current activity.
Average Cadence
Cycling. The average cadence for the current activity.
Average Cadence
Running. The average cadence for the current activity.
Average Descent
The average vertical distance of descent since the last reset.
Average Distance Per Stroke
Swimming. The average distance traveled per stroke during the current activity.
Paddle sports. The average distance traveled per stroke during the current activity.
Average GCT Balance
The average ground contact time balance for the current session.
Average Ground Contact Time
The average amount of ground contact time for the current activity.
Average Heart Rate
The average heart rate for the current activity.
Average Heart Rate %Max.
The average percentage of maximum heart rate for the current activity.
Average Lap Time
The average lap time for the current activity.
Average Left Power Phase
The average power phase angle for the left leg for the current activity.
Average Moving Speed
The average speed when moving for the current activity.
Average Nautical Speed
The average speed in knots for the current activity.
Average Overall Speed
The average speed for the current activity, including both moving and stopped speeds.
Average Pace
The average pace for the current activity.
Average Power
The average power output for the current activity.
Average Right Power Phase
The average power phase angle for the right leg for the current activity.
Average Speed
The average speed for the current activity.
Average Stride Length
The average stride length for the current session.
Average Stroke Rate
Paddle sports. The average number of strokes per minute (spm) during the current activity.
Average Strokes Per Length
The average number of strokes per pool length during the current activity.
Average Swolf
The average swolf score for the current activity. Your swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology). In open water swimming, 25 meters is used to calculate your swolf score.
Average Vertical Oscillation
The average amount of vertical oscillation for the current activity.
Average Vertical Ratio
The average ratio of vertical oscillation to stride length for the current session.
Avg. Left Peak Power Phase
The average power phase peak angle for the left leg for the current activity.
Avg. Nautical SOG
The average speed of travel in knots for the current activity, regardless of the course steered and temporary variations in heading.
Avg. Platform Center Offset
The average platform center offset for the current activity.
Avg. Right Peak Power Phase
The average power phase peak angle for the right leg for the current activity.
Avg. SOG
The average speed of travel for the current activity, regardless of the course steered and temporary variations in heading.
Balance
The current left/right power balance.
Barometric Pressure
The current calibrated environmental pressure.
Battery Hours
The number of hours remaining before the battery power is depleted.
Battery Percentage
The percentage of the battery power remaining.
Bearing
The direction from your current location to a destination. You must be navigating for this data to appear.
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Cadence
Running. The steps per minute (right and left).
Cadence Gauge
Running. A color gauge showing your current cadence range.
Calories
The amount of total calories burned.
COG
The actual direction of travel, regardless of the course steered and temporary variations in heading.
Compass Gauge
The direction you are moving based on the compass.
Compass Heading
Course
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
Destination Location
The position of your final destination.
Destination Waypoint
The last point on the route to the destination. You must be navigating for this data to appear.
Di2 Battery
The remaining battery power of a Di2 sensor.
Distance
The distance traveled for the current track or activity.
Distance Per Stroke
Paddle sports. The distance traveled per stroke.
Distance Remaining
The remaining distance to the final destination. You must be navigating for this data to appear.
Distance To Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
eBike Battery
The remaining battery power of an ebike.
eBike Range
The estimated remaining distance the ebike can provide assistance.
Elapsed Time
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
Elevation
The altitude of your current location above or below sea level.
Estimated Total Distance
The estimated distance from the start to the final destination. You must be navigating for this data to appear.
ETA
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
ETE
The estimated time remaining until you reach the final destination. You must be navigating for this data to appear.
Floors Climbed
The total number of floors climbed up for the day.
Floors Descended
The total number of floors climbed down for the day.
Floors per Minute
The number of floors climbed up per minute.
Flow
The measurement of how consistently you maintain speed and smoothness through turns in the current activity.
Front
The front bike gear from a gear position sensor.
GCT Balance
The left/right balance of ground contact time while running.
GCT Balance Gauge
A color gauge showing the left/right balance of ground contact time while running.
Gear Battery
The battery status of a gear position sensor.
Gear Combo
The current gear combination from a gear position sensor.
Gear Ratio
The number of teeth on the front and rear bike gears, as detected by a gear position sensor.
Gears
The front and rear bike gears from a gear position sensor.
Glide Ratio
The ratio of horizontal distance traveled to the change in vertical distance.
Glide Ratio to Destination
The glide ratio required to descend from your current position to the destination elevation. You must be navigating for this data to appear.
GPS
The strength of the GPS satellite signal.
GPS Elevation
The altitude of your current location using GPS.
GPS Heading
The direction you are moving based on GPS.
Grade
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 ft.) you climb you travel 60 m (200 ft.), the grade is 5%.
Grit
The measurement of difficulty for the current activity based on elevation, gradient, and rapid changes in direction.
Ground Contact Time
The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
Ground Contact Time Gauge
A color gauge showing the amount of time in each step that you spend on the ground while running, measured in milliseconds.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must have wrist-based heart rate or be connected to a compatible heart rate monitor.
Heart Rate %Max.
The percentage of maximum heart rate.
Heart Rate Gauge
A color gauge showing your current heart rate zone.
Heart Rate Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Intensity Factor
The Intensity Factor™ for the current activity.
Interval Average %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Interval Average %Max.
The average percentage of maximum heart rate for the current swim interval.
Interval Average Heart Rate
The average heart rate for the current swim interval.
Interval Distance
The distance traveled for the current interval.
Interval Lengths
The number of pool lengths completed during the current interval.
Interval Maximum %HRR
The maximum percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Interval Maximum %Max.
The maximum percentage of maximum heart rate for the current swim interval.
Interval Maximum Heart Rate
The maximum heart rate for the current swim interval.
Interval Pace
The average pace for the current interval.
Interval Stroke Rate
The average number of strokes per minute (spm) during the current interval.
Interval Strokes Per Length
The average number of strokes per pool length during the current interval.
Interval Stroke Type
The current stroke type for the interval.
Interval Swolf
The average swolf score for the current interval.
Interval Time
The stopwatch time for the current interval.
Lap % Heart Rate Reserve
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Lap 500m Pace
The average rowing pace per 500 meters for the current lap.
Lap Ascent
The vertical distance of ascent for the current lap.
Lap Balance
The average left/right power balance for the current lap.
Lap Cadence
Cycling. The average cadence for the current lap.
Lap Cadence
Running. The average cadence for the current lap.
Lap Descent
The vertical distance of descent for the current lap.
Lap Distance
The distance traveled for the current lap.
Lap Distance Per Stroke
Swimming. The average distance traveled per stroke during the current lap.
Paddle sports. The average distance traveled per stroke during the current lap.
Lap Flow
The overall flow score for the current lap.
Lap GCT Balance
The average ground contact time balance for the current lap.
Lap Grit
The overall grit score for the current lap.
Lap Ground Contact Time
The average amount of ground contact time for the current lap.
Lap Heart Rate
The average heart rate for the current lap.
Lap Heart Rate %Max.
The average percentage of maximum heart rate for the current lap.
Lap Left Peak Power Phase
The average power phase peak angle for the left leg for the current lap.
Lap Left Power Phase
The average power phase angle for the left leg for the current lap.
Lap Normalized Power
The average Normalized Power for the current lap.
Lap Pace
The average pace for the current lap.
Lap Platform Center Offset
The average platform center offset for the current lap.
Lap Power
The average power output for the current lap.
Lap Right Peak Power Phase
The average power phase peak angle for the right leg for the current lap.
Lap Right Power Phase
The average power phase angle for the right leg for the current lap.
Laps
The number of laps completed for the current activity.
Lap SOG
The average speed of travel for the current lap, regardless of the course steered and temporary variations in heading.
Lap Speed
The average speed for the current lap.
Lap Stride Length
The average stride length for the current lap.
Lap Stroke Rate
Swimming. The average number of strokes per minute (spm) during the current lap.
Lap Stroke Rate
Paddle sports. The average number of strokes per minute (spm) during the current lap.
Lap Strokes
Swimming. The total number of strokes for the current lap.
Lap Strokes
Paddle sports. The total number of strokes for the current lap.
Lap Swolf
The swolf score for the current lap.
Lap Time
The stopwatch time for the current lap.
Lap Vertical Oscillation
The average amount of vertical oscillation for the current lap.
Lap Vertical Ratio
The average ratio of vertical oscillation to stride length for the current lap.
Last Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the last completed lap.
Last Lap 500m Pace
The average rowing pace per 500 meters for the last lap.
Last Lap Ascent
The vertical distance of ascent for the last completed lap.
Last Lap Cadence
Cycling. The average cadence for the last completed lap.
Last Lap Cadence
Running. The average cadence for the last completed lap.
Last Lap Descent
The vertical distance of descent for the last completed lap.
Last Lap Distance
The distance traveled for the last completed lap.
Last Lap Distance Per Stroke
Swimming. The average distance traveled per stroke during the last completed lap.
Paddle sports. The average distance traveled per stroke during the last completed lap.
Last Lap Heart Rate
The average heart rate for the last completed lap.
Last Lap Heart Rate %Max.
The average percentage of maximum heart rate for the last completed lap.
Last Lap Max. Power
The top power output for the last completed lap.
Last Lap Normalized Power
The average Normalized Power for the last completed lap.
Last Lap Pace
The average pace for the last completed lap.
Last Lap Power
The average power output for the last completed lap.
Last Lap SOG
The average speed of travel for the last completed lap, regardless of the course steered and temporary variations in heading.
Last Lap Speed
The average speed for the last completed lap.
Last Lap Stroke Rate
Swimming. The average number of strokes per minute (spm) during the last completed lap.
Paddle sports. The average number of strokes per minute (spm) during the last completed lap.
Last Lap Strokes
Swimming. The total number of strokes for the last completed lap.
Last Lap Strokes
Paddle sports. The total number of strokes for the last completed lap.
Last Lap Swolf
The swolf score for the last completed lap.
Last Lap Time
The stopwatch time for the last completed lap.
Last Length Pace
The average pace for your last completed pool length.
Last Length Stroke Rate
The average number strokes per minute (spm) during the last completed pool length.
Last Length Strokes
The total number of strokes for the last completed pool length.
Last Length Stroke Type
The stroke type used during the last completed pool length.
Last Length Swolf
The swolf score for the last completed pool length.
Lat/Lon
The current position in latitude and longitude regardless of the selected position format setting.
The current power phase peak angle for the left leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Left Power Phase
The current power phase angle for the left leg. Power phase is the pedal stroke region where positive power is produced.
Lengths
The number of pool lengths completed during the current activity.
Load
The training load for the current activity. Training load is the amount of excess post-exercise oxygen consumption (EPOC), which indicates the strenuousness of your workout.
Location
The current position using the selected position format setting.
Max. Nautical SOG
The maximum speed of travel in knots for the current activity, regardless of the course steered and temporary variations in heading.
Maximum Ascent
The maximum rate of ascent in feet per minute or meters per minute since the last reset.
Maximum Descent
The maximum rate of descent in meters per minute or feet per minute since the last reset.
Maximum Elevation
The highest elevation reached since the last reset.
Maximum Lap Power
The top power output for the current lap.
Maximum Nautical Speed
The maximum speed in knots for the current activity.
Maximum Power
The top power output for the current activity.
Maximum SOG
The maximum speed of travel for the current activity, regardless of the course steered and temporary variations in heading.
Maximum Speed
The top speed for the current activity.
Minimum Elevation
The lowest elevation reached since the last reset.
Moving Time
The total time moving for the current activity.
Multisport Time
The total time for all sports in a multisport activity, including transitions.
Muscle O2 Saturation %
The estimated muscle oxygen saturation percentage for the current activity.
Nautical Distance
The distance traveled in nautical meters or nautical feet.
Nautical SOG
The actual speed of travel in knots, regardless of the course steered and temporary variations in heading.
Nautical Speed
The current speed in knots.
Next Split Distance
Running. The total distance of the next split.
Next Split Target Pace
Running. The target pace for the next split.
Next Waypoint
The next point on the route. You must be navigating for this data to appear.
Normalized Power
The Normalized Power™ for the current activity.
Off Course
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
Overall Ahead/Behind
Running. The overall time ahead or behind of the target pace.
Pace
The current pace.
PacePro Gauge
Running. Your current split pace and your target split pace.
Pedal Smoothness
The measurement of how evenly a rider is applying force to the pedals throughout each pedal stroke.
Performance Condition
The performance condition score is a real-time assessment of your ability to perform.
The platform center offset. Platform center offset is the location on the pedal platform where force is applied.
Power
Cycling. The current power output in watts.
Power
Skiing. The current power output in watts. Your device must be connected to a compatible heart rate monitor.
Power Gauge
A color gauge showing your current power zone.
Power to Weight
The current power measured in watts per kilogram.
Power Zone
The current range of power output (1 to 7) based on your FTP or custom settings.
Rear
The rear bike gear from a gear position sensor.
Repeat On
The timer for the last interval plus the current rest (pool swimming).
Reps
During a strength training activity, the number of repetitions in a workout set.
Respiration Rate
Your respiration rate in breaths per minute (brpm).
Rest Timer
The timer for the current rest (pool swimming).
The current power phase peak angle for the right leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Right Power Phase
The current power phase angle for the right leg. Power phase is the pedal stroke region where positive power is produced.
Set Timer
During a strength training activity, the amount of time spent in the current workout set.
Speed
The current rate of travel.
Speed Over Ground
The actual speed of travel, regardless of the course steered and temporary variations in heading.
Split Distance
Running. The total distance of the current split.
Split Distance Remaining
Running. The remaining distance of the current split.
Split Pace
Running. The pace for the current split.
Split Target Pace
Running. The target pace for the current split.
Steps
The number of steps taken during the current activity.
Stopped Time
The total time stopped for the current activity.
Stress
Your current stress level.
Stride Length
The length of your stride from one footfall to the next, measured in meters.
Stroke Rate
Swimming. The number of strokes per minute (spm).
Stroke Rate
Paddle sports. The number of strokes per minute (spm).
Strokes
Swimming. The total number of strokes for the current activity.
Strokes
Paddle sports. The total number of strokes for the current activity.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Swim Time
The swimming time for the current activity, not including rest time.
Temperature
The environmental temperature during the activity. Your body temperature affects the temperature sensor. You can pair a tempe™ sensor with your device to provide a consistent source of accurate temperature data.
Time in Zone
The time elapsed in each heart rate or power zone.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Time of Day (Seconds)
The time of day including seconds.
Timer
The current time of the countdown timer.
Time Seated
The time spent seated while pedaling for the current activity.
Time Seated Lap
The time spent seated while pedaling for the current lap.
Time Standing
The time spent standing while pedaling for the current activity.
Time Standing Lap
The time spent standing while pedaling for the current lap.
Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
Torque Efficiency
The measurement of how efficiently a rider is pedaling.
Total Ascent
The total elevation distance ascended since the last reset.
Total Ascent/Descent Gauge
The total elevation distances ascended and descended during the activity or since the last reset.
Total Descent
The total elevation distance descended since the last reset.
Total Hemoglobin
The estimated total hemoglobin concentration in the muscle.
Training Effect Gauge
The impact of the current activity on your aerobic and anaerobic fitness levels.
Training Stress Score
The Training Stress Score™ for the current activity.
Velocity Made Good
The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
Vertical Dist. to Dest.
The elevation distance between your current position and the final destination. You must be navigating for this data to appear.
The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
Vertical Oscillation Gauge
A color gauge showing the amount of bounce while you are running.
Vertical Ratio
The ratio of vertical oscillation to stride length.
Vertical Ratio Gauge
A color gauge showing the ratio of vertical oscillation to stride length.
Vertical Speed
The rate of ascent or descent over time.
Vertical Speed to Target
The rate of ascent or descent to a predetermined altitude. You must be navigating for this data to appear.
Work
The accumulated work performed (power output) in kilojoules.
Copyright © Garmin. All rights reserved.GUID-DF9BDE35-F592-4CD8-872D-A2910FAFC147 v8
