Calibrating the Barometric Altimeter
Your watch was already calibrated at the factory, and the watch uses automatic calibration at your GPS starting point by default. You can manually calibrate the barometric altimeter if you know the correct elevation.
- Hold MENU.
- Select .
Select an option:
To calibrate automatically from your GPS starting point, select Auto Cal., and select an option.
To enter the current elevation manually, select .
To enter the current elevation from the digital elevation model, select .
NOTE: Some devices require a phone connection to use DEM for calibration. -
To enter the current elevation from your GPS starting point, select .
Parent Topic: Altimeter Settings
