Pairing Your Smartphone
To use the connected features on your watch, you must pair it directly through the Garmin Connect™ app, instead of from the Bluetooth® settings on your smartphone.
  1. From the app store on your smartphone, install and open the Garmin Connect app.
  2. Select an option to enable pairing mode on your watch:
    • During the initial setup, select Yes when you are prompted to pair with your smartphone.
    • If you previously skipped the pairing process, hold MENU, and select Pair Phone.
  3. Select an option to add your watch to your account:
    • If this is the first time you are pairing a device with the Garmin Connect app, follow the on-screen instructions.
    • If you already paired another device with the Garmin Connect app, from the Menu or Menu menu, select Garmin Devices > Add Device, and follow the on-screen instructions.
Copyright © Garmin. All rights reserved.GUID-DF9BDE35-F592-4CD8-872D-A2910FAFC147 v8
