Before you go skiing or snowboarding, you should charge the device completely (Charging the Device).
Select
Wait while the device locates satellites.
Select
START to start the timer.
History is recorded only while the timer is running.
Start your activity.
The auto run feature is turned on by default. This feature automatically records new ski runs based on your movement.
The
Auto Pause® feature is turned on by default (Using
Auto Pause). The timer pauses when you stop moving downhill and when you board the chairlift.
If necessary, start moving downhill to restart the timer.
After you complete your activity, select
