Data Fields
The margin of error for your exact location. For example, your GPS location is accurate to within +/- 3.65 m (12 ft.).
The average percentage of maximum heart rate for the current activity.
The uncalibrated ambient pressure.
The total elevation distance ascended since the last reset.
The average vertical distance of ascent since the last reset.
The average left/right power balance for the current activity.
The average cadence for the current activity.
The average vertical distance of descent since the last reset.
The average heart rate for the current activity.
The average lap time for the current activity.
The average pace for the current activity.
The average power output for the current activity.
The average speed for the current activity.
Average distance traveled per stroke during the current activity.
Average strokes per minute (spm) during the current activity.
Average number of strokes per length during the current activity.
The average Swolf score for the current activity. Swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology).
The current left/right power balance.
The three-second moving average of the left/right power balance.
The calibrated current pressure.
The remaining battery power.
The direction from your current location to a destination. You must be navigating for this data to appear.
The number of revolutions of the crank arm or number of steps per minute.
The amount of total calories burned.
The direction you are moving based on the compass.
Compass heading. A visual representation of the direction in which the device is pointing.
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
The current day, month, and year.
The total elevation distance descended for the current activity.
The distance traveled for the current track or activity.
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
The altitude of your current location above or below sea level.
Final destination. The last point on the route or course.
The remaining distance to the final destination. You must be navigating for this data to appear.
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
The estimated time remaining until you reach the final destination. You must be navigating for this data to appear.
The position of your final destination.
The elevation distance between your current position and the final destination. You must be navigating for this data to appear.
The rate of ascent or descent to a predetermined altitude. You must be navigating for this data to appear.
Ground contact time. The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
The ratio of horizontal distance traveled to the change in vertical distance.
The strength of the GPS satellite signal.
The altitude of your current location using GPS.
GPS heading. The direction you are moving based on GPS.
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 feet) you climb you travel 60 m (200 feet), the grade is 5%.
The glide ratio required to descend from your current position to the destination elevation. You must be navigating for this data to appear.
The direction you are moving.
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
The percentage of maximum heart rate.
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
The distance traveled for the current interval.
Amount of pool lengths completed during the current interval.
The average pace for the current interval.
Total number of strokes for the current interval.
Average distance traveled per stroke during the current interval.
Average strokes per minute (spm) during the current interval.
The average Swolf score for the current interval. Swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology).
The stopwatch time for the current interval.
The accumulated work performed (power output) in kilojoules.
The vertical distance of ascent for the current lap.
The average left/right power balance for the current lap.
The average cadence for the current lap.
The vertical distance of descent for the current lap.
The distance traveled for the current lap.
The average heart rate for the current lap.
The average pace for the current lap.
The average power output for the current lap.
The number of laps completed for the current activity.
The average speed for the current lap.
The stopwatch time for the current lap.
The stopwatch time for all the completed laps.
The distance traveled for the last completed interval.
The current position in latitude and longitude regardless of the selected position format setting.
Amount of pool lengths completed during the current activity.
The average percentage of maximum heart rate for the current lap.
Amount of pool lengths completed during the last completed interval.
The average pace for the last completed interval.
Total number of strokes for the last completed interval.
Average distance traveled per stroke during the last completed interval.
Average strokes per minute (spm) during the last completed interval.
Average number of strokes per length during the last completed interval.
The average Swolf score for the last completed interval. Swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology).
The stopwatch time for the last completed interval.
The stroke type used during the last completed interval.
The vertical distance of ascent for the last completed lap.
The average cadence for the last completed lap.
The vertical distance of descent for the last completed lap.
The distance traveled for the last completed lap.
The average heart rate for the last completed lap.
The average pace for the last completed lap.
The average speed for the last completed lap.
The stopwatch time for the last completed lap.
The average pace for your last completed pool length.
Number of strokes for the last completed pool length.
Average strokes per minute (spm) during the last completed pool length.
The Swolf score for the last completed pool length. Swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology).
The stroke type used during the last completed pool length.
The current position using the selected position format setting.
The maximum rate of ascent in feet per minute or meters per minute since the last reset.
The maximum rate of descent in meters per minute or feet per minute since the last reset.
The highest elevation reached for the current track or activity.
The top power output for the current activity.
The top speed for the current activity.
The maximum temperature recorded in the last 24 hours.
The lowest elevation reached since the last reset.
The minimum temperature recorded in the last 24 hours.
The average speed while moving for the current activity.
A running tally of the time spent moving since the last reset.
The next point on the route. You must be navigating for this data to appear.
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
The estimated time remaining until you reach the next point in your route. You must be navigating for this data to appear.
Next waypoint vertical distance. The elevation distance between your current position and the next waypoint in the route. You must be navigating for this data to appear.
This is a blank data field.
A running tally of distance traveled for all trips. This total does not clear when resetting the trip data.
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
The current pace.
Pedal smoothness. The measurement of how evenly a rider is applying force to the pedals throughout each pedal stroke.
The current power output in watts.
The 10-second moving average of power output.
The 30-second moving average of power output.
The three-second moving average of power output.
The current range of power output (1 to 7) based on your FTP or custom settings.
The time remaining until the start of your next timed swim interval.
The timer for the current rest break.
The current rate of travel.
The number of steps recorded by the foot pod.
A running tally of the time spent not moving since the last reset.
The stopwatch time for the current activity.
The current stroke type.
Total number of strokes for the current activity.
The time of sunrise based on your GPS position.
The time of sunset based on your GPS position.
The temperature of the air. Your body temperature affects the temperature sensor.
The time since you started the activity, not including time while the activity was paused.
The current time of the countdown timer.
The direction in which you must move to get back on the route. You must be navigating for this data to appear.
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Torque efficiency. The measurement of how efficiently a rider is pedaling.
The distance traveled for the current track.
The angle of difference (in degrees) between the bearing to your destination and your current course. L means turn left. R means turn right. You must be navigating for this data to appear.
The rate of ascent or descent over time.
Velocity made good. The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
Vertical oscillation. The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
The amount of power output in watts per kilogram.
