Editing a Route
- Hold MENU.
- Select .
- Select a route.
- Select Edit.
- Select a point.
Select an option:
To view the point on the map, select Map.
To change the order of the point on the route, select Move Up or Move Down.
To insert an additional point on the route, select Insert.
The additional point is inserted before the point you are editing.
To add a point to the end of the route, select Next Point.
To remove the point from the route, select Remove.
Parent Topic: Routes
