Setting the Compass Heading From the home page, press or to scroll through the widget glances. Select Navigation, and scroll to the compass. Press OK to open the options menu. Select Lock Heading. Point the top of the device toward your heading, and press OK. When you deviate from the heading, the compass displays the direction from the heading and the degree of deviation. Parent Topic: Navigation Widget
Setting the Compass Heading From the home page, press or to scroll through the widget glances. Select Navigation, and scroll to the compass. Press OK to open the options menu. Select Lock Heading. Point the top of the device toward your heading, and press OK. When you deviate from the heading, the compass displays the direction from the heading and the degree of deviation. Parent Topic: Navigation WidgetHomeNavigation WidgetSetting the Compass Heading
