Deleting a Weather Location
You must set the weather location before you can delete it (Setting the Weather Location).
You can delete an expired forecast or a forecast for a location that you no longer need.
  1. From the home page, press Up arrow or Down arrow to scroll through the widget glances.
  2. Select Weather.
  3. Press OK to open the options menu.
  4. Select Remove.
GUID-802DEF62-EBB2-463C-8C51-C58FB29F89E3 v8
October 2026
