Calibrating the Compass
NOTICE
Calibrate the electronic compass outdoors. To improve heading accuracy, do not stand near objects that influence magnetic fields, such as vehicles, buildings, and overhead power lines.
If you experience irregular compass behavior, for example, after moving long distances or after extreme temperature changes, you can manually calibrate the compass.
  1. From the home page, press Up arrow or Down arrow to scroll through the widget glances.
  2. Select Navigation, and scroll to the compass.
  3. Press OK to open the options menu.
  4. Select Calibrate.
  5. Follow the on-screen instructions.
GUID-802DEF62-EBB2-463C-8C51-C58FB29F89E3 v8
October 2026
