Navigation Widget
From the home page, press Up arrow or Down arrow to scroll through the widget glances. Select Navigation, and press Up arrow or Down arrow to scroll through the navigation pages.
Map
Bearing pointer represents your location on the map. As you travel, Bearing pointer moves and displays your path. Depending on your zoom level, waypoint names and symbols may appear on the map. You can zoom in on the map to see more detail. When you are navigating to a destination, your route is marked with a line on the map. When you start tracking, your activity recording appears on the map.
Compass
Shows your heading.
Location
Displays your current GPS location and elevation. Each message you send includes a link to your current location. You can also send your GPS coordinates as text within a message.
GUID-802DEF62-EBB2-463C-8C51-C58FB29F89E3 v8
October 2026
