Resetting All Default Settings
Before you reset your device, you should sync your device with the Garmin Explore™ app to upload your activity data.
You can reset all device settings to the factory default values.
  1. From the home page, press OK to open the main menu.
  2. Select Settings > System > Reset Device.
  3. Select an option:
    • To reset all of the device settings to the factory default values and save all user-entered information and activity history, select Reset Default Settings.
    • To reset all of the device settings to the factory default values and delete all user-entered information and activity history, select Delete Data and Reset Settings.
GUID-802DEF62-EBB2-463C-8C51-C58FB29F89E3 v8
October 2026
