Position Format Settings
NOTE: You should not change the position format or the map datum coordinate system unless you are using a map or chart that specifies a different position format.
From the home page, press OK to open the main menu. Select Settings > System > Units > Position Format.
Format
Sets the position format in which a location reading appears.
Datum
Sets the coordinate system on which the map is structured.
Spheroid
Shows the coordinate system the device is using. The default coordinate system is WGS 84.
GUID-802DEF62-EBB2-463C-8C51-C58FB29F89E3 v8
September 2026
