Creating a Custom Activity Profile
Select
> Settings > Activity Profiles > Add New.
Select a sport.
NOTE: The default sports use the default icon. If you select Other, you can select a different icon.
- Select an accent color.
Select a profile name or enter a custom name.
Duplicate profile names include a number, for example: Triathlon(2).
Select an option:
Select Use Default to create your custom profile starting from the system default settings.
Select a copy of an existing profile to create your custom profile starting from one of your saved profiles.
NOTE: If you are creating a custom multisport profile, you are prompted to select two or more profiles and include transitions. -
Select an option:
Select Edit Settings to customize specific profile settings.
Select Done to save and use the custom profile.
Parent Topic: Activity Profiles
