Before you can view running dynamics, you must put on the
HRM-Run™ accessory or
HRM-Tri™ accessory and pair it with your device (Pairing Your
ANT+ Sensors).
If your
Forerunner® was packaged with the heart rate monitor, the devices are already paired, and the
Forerunner is set to display running dynamics.
Select an option:
If your
Forerunner was packaged with the heart rate monitor, put on your heart rate monitor, and go to step 2.
If your heart rate monitor was purchased separately, select
Select
Primary Metric.
Select
Cadence,
Ground Contact Time, or
Vertical Oscillation.
The primary metric appears as the top field on the data screen with a corresponding position on the color gauge.
Go for a run.
Scroll to the running dynamics screen to view your metrics.
If necessary, hold
to change the primary metric during your run.
