Running Dynamics
You can use your compatible Forerunner® device paired with the HRM-Run™ accessory or HRM-Tri™ accessory to provide real-time feedback about your running form. If your Forerunner device was packaged with the heart rate monitor, the devices are already paired.
The heart rate monitor has an accelerometer in the module that measures torso movement in order to calculate six running metrics.
NOTE:
The
HRM-Run accessory and the
HRM-Tri accessory are compatible with several
ANT+® fitness products and can display heart rate data when paired. The running dynamics features are available on only some
Garmin® devices.
- Cadence
Cadence is the number of steps per minute. It displays the total steps (right and left combined).
- Vertical oscillation
Vertical oscillation is your bounce while running. It displays the vertical motion of your torso, measured in centimeters for each step.
- Ground contact time
Ground contact time is the amount of time in each step that you spend on the ground while running. It is measured in milliseconds.NOTE: Ground contact time is not available while walking.
- Training with Running Dynamics
- Color Gauges and Running Dynamics Data
- Tips for Missing Running Dynamics Data
Parent Topic: Compatible Heart Rate Monitors
