Changing Your Activity Profile
The device has seven default activity profiles. You can modify any of the saved activity profiles.
TIP:
The default activity profiles use a specific accent color for each sport. The multisport activity profile changes the accent color when you switch sport segments.
- Select .
- Select a profile.
- If necessary, select Name, and enter a new name for the profile.
- If necessary, select Color, and select an accent color for the profile.
- Select Apply Profile.
Parent Topic: Activity Profiles
