Setting a Recurring Alert
A recurring alert notifies you each time the device records a specified value or interval. For example, you can set the device to alert you every 30 minutes.
  1. Select > Activity Settings > Alerts > Add New.
  2. Select an option:
    • Select Custom, select a message, and select an alert type.
    • Select Time, Distance, or Calories.
  3. Enter a value.
Each time you reach the alert value, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds).
Copyright © Garmin. All rights reserved.GUID-3F6E0495-3A1D-49FA-888B-B002BB2B6114 v5
