Data Fields
Some data fields require ANT+® accessories to display data.
The current power output as a percentage of functional threshold power.
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
The 10-second moving average of the left/right power balance.
The 10-second moving average of power output.
The 30-second moving average of the left/right power balance.
The 30-second moving average of power output.
The 30-second moving average of vertical speed.
The three-second moving average of the left/right power balance.
The three-second moving average of power output.
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
The average left/right power balance for the current activity.
Cycling. The average cadence for the current activity.
Running. The average cadence for the current activity.
The average heart rate for the current activity.
The average percentage of maximum heart rate for the current activity.
The average lap time for the current activity.
The average pace for the current activity.
The average power output for the current activity.
The average speed for the current activity.
The average distance traveled per stroke during the current activity.
The average number of strokes per minute (spm) during the current activity.
The average number of strokes per length during the current activity.
The average swolf score for the current activity. Your swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology). In open water swimming, 25 meters is used to calculate your swolf score.
The average amount of ground contact time for the current activity.
The average power phase angle for the left leg for the current activity.
The average power phase peak angle for the left leg for the current activity.
The average power phase angle for the right leg for the current activity.
The average power phase peak angle for the right leg for the current activity.
The average amount of vertical oscillation for the current activity.
The current left/right power balance.
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Running. The steps per minute (right and left).
The amount of total calories burned.
The remaining battery power of a Di2 sensor.
The distance traveled for the current track or activity.
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
The altitude of your current location above or below sea level.
The front bike gear from a Di2 sensor.
The number of teeth on the front and rear bike gears.
The front and rear bike gears from a Di2™ sensor.
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 ft.) you climb you travel 60 m (200 ft.), the grade is 5%.
The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
The direction you are moving.
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
The percentage of maximum heart rate.
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
The average percentage of maximum heart rate for the current swim interval.
The average heart rate for the current swim interval.
The maximum percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
The maximum percentage of maximum heart rate for the current swim interval.
The maximum heart rate recorded during the current swim interval.
The Intensity Factor™ for the current activity.
The distance traveled for the current swim interval.
The number of pool lengths completed during the current interval.
The average pace for the current swim interval.
The average distance traveled per stroke during the current interval.
The average number of strokes per minute (spm) during the current interval.
The total number of strokes for the current interval.
The average number of strokes per length during the last completed interval.
The current stroke type for the interval.
The average swolf score for the current interval.
The stopwatch time for the current swim interval.
The current power phase angle for the left leg. Power phase is the pedal stroke region where you produce positive power.
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
The average left/right power balance for the current lap.
Cycling. The average cadence for the current lap.
Running. The average cadence for the current lap.
The distance traveled for the current lap.
The average amount of ground contact time for the current lap.
The average heart rate for the current lap.
The average percentage of maximum heart rate for the current lap.
The average power phase angle for the left leg for the current lap.
The average power phase peak angle for the left leg for the current lap.
The average Normalized Power for the current lap.
The average pace for the current lap.
The average power output for the current lap.
The average power phase angle for the right leg for the current lap.
The average power phase peak angle for the right leg for the current lap.
The number of laps completed for the current activity.
The average speed for the current lap.
The stopwatch time for the current lap.
The average amount of vertical oscillation for the current lap.
The distance traveled for the last completed swim interval.
The average pace for the last completed swim interval.
The average distance traveled per stroke during the last completed interval.
The average number of strokes per minute (spm) during the last completed interval.
The total number of strokes for the last completed interval.
The average swolf score for the last completed interval.
The stopwatch time for the last completed swim interval.
Cycling. The average cadence for the last completed lap.
Running. The average cadence for the last completed lap.
The distance traveled for the last completed lap.
The average Normalized Power for the last completed lap.
The average pace for the last completed lap.
The average power output for the last completed lap.
The average speed for the last completed lap.
The stopwatch time for the last completed lap.
The average pace for your last completed pool length.
The average number strokes per minute (spm) during the last completed pool length.
The total number of strokes for the last completed pool length.
The stroke type used during the last completed pool length.
The swolf score for the last completed pool length.
The current power phase peak angle for the left leg. Power phase peak is the angle range over which you produce the peak portion of the driving force.
The number of pool lengths completed during the current activity.
The top power output for the current lap.
The top power output for the current activity.
The top speed for the current activity.
The distance traveled in nautical meters or nautical feet.
The current speed in knots.
The Normalized Power™ for the current activity.
The current pace.
The platform center offset. Platform center offset is the location on the pedal platform where you apply force.
The average platform center offset for the current activity.
The average platform center offset for the current lap.
The measurement of how evenly a rider is applying force to the pedals throughout each pedal stroke.
The current power output in watts.
The current power measured in watts per kilogram.
The current range of power output (1 to 7) based on your FTP or custom settings.
The current power phase angle for the right leg. Power phase is the pedal stroke region where you produce positive power.
The rear bike gear from a Di2 sensor.
The timer for the last interval plus the current rest (pool swimming).
The timer for the current rest (pool swimming).
The current power phase peak angle for the right leg. Power phase peak is the angle range over which you produce the peak portion of the driving force.
The current rate of travel.
The number of strokes per minute (spm).
The total number of strokes for the current activity.
The time of sunrise based on your GPS position.
The time of sunset based on your GPS position.
The time elapsed in each heart rate or power zone.
The time of day based on your current location and time settings (format, time zone, daylight saving time).
The stopwatch time for the current activity.
The time spent seated while pedaling for the current activity.
The time spent seated while pedaling for the current lap.
The time spend standing while pedaling for the current activity.
The time spend standing while pedaling for the current lap.
The measurement of how efficiently a rider is pedaling.
The total elevation distance ascended since the last reset.
The total elevation distance descended since the last reset.
The current impact (1.0 to 5.0) on your aerobic fitness.
The Training Stress Score™ for the current activity.
The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
The rate of ascent or descent over time.
The accumulated work performed (power output) in kilojoules.
