Going for a Run Using a Foot Pod
Before you go for a run, you must pair the foot pod with your device (Pairing Your ANT+ Sensors).
You can run indoors using a foot pod to record pace, distance, and cadence. You can also run outdoors using a foot pod to record cadence data with your GPS pace and distance.
- Install your foot pod according to the accessory instructions.
- If necessary, turn off GPS (Training Indoors).
- Select to start the timer.
- Go for a run.
- After you complete your run, select to stop the timer.
Parent Topic: Foot Pod
