Setting Range Alerts
A range alert notifies you when the device is above or below a specified range of values. For example, if you have an optional heart rate monitor, you can set the device to alert you when your heart rate is below 90 beats per minute (bpm) and over 180 bpm.
- Select .
- Select Heart Rate or Pace.
- Turn on the alert.
- Enter the minimum and maximum values.
Each time you exceed or drop below the specified range, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds).
Parent Topic: Alerts
